D4B DC mods like the LD340 DC mods?
I hate it when I see perfectly good parts mutilated by idiots. You think it's savable?
It should be able to be cleaned up on a mill to look decent. If nothing else, it can be a spreadbore intake. I need to dig it out, take it to my buddy with a mill and 60 years of machining experience and tell him...."I doubt you can fix this, but see what you can do." :poke: :lol:
I've seen some REALLY good jobs on some of those to a spread bore, you'd think Edelbrock made a run, but they never did. There are even instructions in the MP engine book on how to do it.
There were large, 750+ cfm OEM AVS carbs, usually found on High Performance 440's.
I got one for a 383 but I guess it was the same as the 340 carb. I figured that and a Racer brown or E4. I hope to find a cam that will work with the pistons that are in it. That also depends on if I can get a thinner head gasket (MLS?) to bring the compression up that much more. I'm thinking this could be a good mpg engine, have a wide rpm range, and still be able to efficiently pass a semi with a 3.21 SG.
The MLS gaskets aren't all that thin. These are good ones. .028 compressed.
i recently just did a little road trip in a 68 dart with a 273 2bbl and a no-grip rear end. zero-point-zero problems passing semi's, keeping up with traffic or tackling the mountain pass to get back home. all while clicking off high teens/low 20's mpg.
keep the cam small, keep the carb reasonable, bump the compression to a moderate amount and it'll be a ripper, have great street manners and return decent mileage.
That's what I'm shooting for.
i'm sure that many will take umbrage at this, but looking back on your spec and ideas i'd forgo the "commando cam" or the E4. don't get me wrong, it's a cool cam if you're going for that type build but i think that there's many improved, more modern grinds out there that would suit what you're doing a lot better.
the stock 9:1 will be plenty for a broad range of use and should run on pretty much any fuel should you get jammed up while out and about. if you wind up needing to open it up, then i'd burn that bridge when you get there.
double check the primaries/secondaries on the carb to confirm that it's a "small" rather than the bigger 750, which i think would be too much carb for what it seems like you're trying to accomplish.
The best thing to do for us right now is probably to call Jim at Racer Brown and tell him my compression, gear, intake and carb, and intentions. We'll keep the heads on but replace the cam and lifters when the intake goes on. Dual point distributor as well
100% agreement. Jim will steer ya right!
Unless you use the AVS2 1412 800 CFM carburetor. I'm pretty sure that a TQ's secondary blades will still require an adapter to fit that manifold. I've always heard that the notch is for the three barrel Holley carburetors that were popular at that time.
That is correct, that’s what the notch is for. The mod is also to allow the use of a TQ carb, grinding is for the larger secondaries and the carb will them fit. I have an LD340 intake that’s been modded just like this.
Yes, vacuum secondary. Each cylinder is effectively only seeing 425 cfm with a dual plane manifold if the center divider is not cut down in the intake manifold.
A stock 4 barrel on a 273 is about that cfm for all the barrels wide open.
Oh, and stock was a single plane manifold on the commando engine, right?
Yes, a very flat, low profile, open plenum. This is a aluminum prototype cast from the iron molds and blueprints.
Well truth be told, I prefer a thermoquad on any street engine and that would require notching clearance in a dual plane manifold or a spacer, but then your more than likely going to run into hood clearance problems.
