Won't the heat riser passage just burn through?
Only if you don't deal with the other related mod - either freezing the heat riser valve in place open, or doing away with it and welding up the holes... which would be my preference.
I forgot about all that, I've cheated those problems out with headers...Only if you don't deal with the other related mod - either freezing the heat riser valve in place open, or doing away with it and welding up the holes... which would be my preference.
