Dad's Swinger getting a makeover
Nice work, keep it up!
BTW, did you know that you need to change the truck pan and pickup to a car pan and pickup on the engine?
Looking good! How are the quarters fitting with the doors? My drivers side fit pretty good, but the passenger side is being a pain.
Few issues with form/fit but it was expected and very easily fixed. There is a small gap between the door and the quarter on both sides but it was for the most part there before. It wil need a bit of adjustment but I think the bolts behind the kick panel will allow me to adjust the whole door back a tad. And if not no biggie it was like that before and the doors open/close fine
As u see along with changing one piece at a time we used many braces and other methods of support to assure the best possible chance of it not moving while getting it back together
a8-jpg.1714721254
not to much done tonight only had a couple hours but got the rest of the drivers side quarter welded on and trunk floor almost out. Tomorrow will get the trunk floor done and a few repairs under the rear deck then grind flat all the spot welds and fix and fill where the quarter and the rear pillar come together.
229-jpg.1714721540
a1-jpg.1714721541
t1-jpg.1714721542
then got it all together and out of the garage and there is still a lot of final tweeking of adjusting doors and trunk and getting all the new gaskets and seals installed. Much of it will wait until or during the final body work stages (which will come after the motor is in)
its not perfect and not a show car and just a driver so over all i am very happy with the way its coming out so far
c14-jpg.1714722656
c15-jpg.1714722657
c18-jpg.1714722658
c16-jpg.1714722659
c17-jpg.1714722660
c3-jpg.1714722661
c2-jpg.1714722662
c1-jpg.1714722663
they are not going to be perfect time to clean and paint some parts so they are at least grease free and clean when they go back in. i just messed with the rotor but nothing great because i will put on new ones and it is getting new ball joints and stuff also.
p3-jpg.1714723005
p4-jpg.1714723006
p6-jpg.1714723007
p7-jpg.1714723008
p13-jpg.1714723009
p14-jpg.1714723010
p15-jpg.1714723011
p17-jpg.1714723012
p19-jpg.1714723013
p18-jpg.1714723014
then i pressure washed the engine bay and the under body. it wont b perfect but i am working on getting the engine bay cleaned up and some paint in there and going to undercoat the whole bottom of the car while i got it apart.
the engine bay was already black and planning on painting ( i changed my mind) the car black and silver with the bottom black so i decided to leave the engine bay black
c8-jpg.1714724820
c2-jpg.1714724821
c1-jpg.1714724822
c36-jpg.1714724823
c32-jpg.1714724824
c23-jpg.1714724825
c27-jpg.1714724826
c29-jpg.1714724827
c28-jpg.1714724828
c22-jpg.1714724829
