Daily Insight
Man, I'm startin' ta tear up after that one Ramcharger! lol
LOL!
Here's a couple more:
"Whatever is in any way beautiful hath its source of beauty in itself, and is complete in itself; praise forms no part of it. So it is none the worse nor the better for being praised."
"A man makes no noise over a good deed, but passes on to another as a vine to bear grapes again in season"
~Marcus Aurelius Antoninus~ [A.D. 121-180]
Procrastination is the natural assassin of opportunity.
-- Anonymous
Winners Make Their Own Good Luck
To reap the gains and windfalls of a successful business, entrepreneurs must look to a set of attitudes they will find only within themselves
We once heard a mathematics professor state, "The parameters of luck are unknown to us." In other words, luck can't be explained by any specific factor, it's a matter of chance. We thought the statement made a lot of sense, but we were intrigued by the notion that what we call "luck" could be explained by a set of variables or elements that had not yet been studied. So we decided to carry out our own research.
What we did was relatively easy: We spoke at length with people who thought their lives had been blessed by good fortune, our goal being to try and figure out what factors they had in common. After four years of interviews and research, we could clearly identify a list of shared traits, ones we will shortly examine in greater depth. WHOM FORTUNE FAVORS. But first, an additional word of explanation: When undertaking our project, we decided to study of biographies of "prosperous" personalities ("prosperous" understood in its broadest sense). We studied not only individuals enjoying good marriages or financial wealth, but also those who have made valuable contributions to society and who see their own lives as being filled with creativity, self-fulfillment, and meaning. By taking this tack, we were able to include artists, scientists, and athletes in our sample. What our research revealed can be summarized in a single simple sentence: We make our own good luck. What these creators of good luck have in common can be summarized in the following five main principles: • Responsibility If there is a common factor that is evident among all the creators of good luck, it is that they know themselves to be responsible for their own actions. In other words, when things go wrong or the outcome of any given situation is other than intended, they never point the finger of blame at external factors or other individuals. Instead, they look to themselves and ask, "What have I done for this to occur?"
Free of any kind of "victimism," when they run into personal or professional difficulties, they ask themselves how and to what extent they are responsible for the situation in which they find themselves? Then they act accordingly to solve whatever adverse circumstance they have encountered. This is where the second principle comes in. • Learning from Mistakes Creators of good luck don't see a mistake as a failure. Instead, a mistake is an opportunity for learning. Thomas Edison is the classic example. History tells us that the inventor made more than 1,000 attempts before inventing the first long-lasting electric light bulb. Until then, all his trials and experiments led to durations of no more than a few minutes before air would filter into the glass bulb, supplying the oxygen that led to the combustion of the various filaments he tried. The story goes that one of Edison's colleagues asked him, "Mr. Edison, don't you feel you are a failure?" Lacking any sense of vanity, the great man answered, "Not at all. Now, I definitely know more than a thousand ways how NOT to make a light bulb." Sure enough, just a few days later, the man whose brainstorms would remake the world finally turned his inspiration into a practical concept. By the way, the very first light bulb was invented by Sir Joseph Wilson Swan, who demonstrated the theoretical concept but gave up trying to develop a practical application after only three attempts. By contrast, Edison made his own good luck and designed a working light bulb. This takes us to our third principle. • Perseverance Creators of good luck don't give up. They don't postpone. They don't "leave it for another day." The formula is quite simple: When a problem or situation arises that requires attention, they act immediately. And what they do is one of the following three things: they either solve it without delay, delegate, or forget about it. In other words, they don't carry a list of "things to do" in their brain. Instead, they resolve problems and situations as quickly as possible. This enables their energy to be fully focused on their work and avoid conscious or unconscious distractions, which only generate inefficiency.
Confidence This is one of the most overlooked principles, yet one of the most powerful. Confidence is divided into two parts: confidence in yourself and confidence in the others.
Confidence in yourself is essential, and those who create their own good luck are remarkable for their high degrees of assertiveness and self-esteem. These qualities allow them to keep to their purpose, to persevere, and to work to create the conditions that ultimately do so much to achieve objectives. Also, they are great visualizers. They use their imaginations -- specifically, their visualizing techniques -- to form mental images of their goals. Without the confidence to pursue this vision, visualizing would make no sense. Furthermore, and closely linked to assertiveness and self-esteem, the people we studied
exhibit both trust in others and respect for them, seeing people they know, people they work with, those who surround them as major sources of opportunity. This doesn't mean that one must be naive and trust anybody and everybody who makes a proposal. Instead, it speaks to the trait of seeing others as sources of opportunity for achievement. Without confidence there is no way to "give yourself" to the situation. If there is no intimacy -- if it is ruled out by paranoia or rampant suspicion, for example -- there can be no opening up to others. Hence, there can be no room for dialogue or for the genuine and sincere exchange of opinions. Without this, any initiative proceeds more slowly until, eventually, it simply withers and dies. Confidence is a fundamental variable, and this takes us to the last principle. • Cooperation The term "synergy" is one we heard often when interviewing those who create their own good luck. Trust in others leads to solid a network of work colleagues and friends, which, in turn, brings into play substantially more resources to carry out projects than if they were managed alone. The logic is based on cooperation rather than competitiveness. Such people are aware of the fact that, at the most basic level, any project or undertaking takes place in the context of the broader group, and that all parties must have a realistic prospect of emerging as winners if all concerned are to produce their best efforts. As we have seen, whether or not one can create good luck basically depends on an attitude towards oneself, towards others, and towards life. It is also tied to the perception that the individual is much more of a cause than an effect. And above all, to the realization that one must make oneself the creator of the conditions that foster success and the achievement of specific, visualized goals. LUCK OR GOOD LUCK? Think of luck -- the sort that wins lotteries -- as the end result of a random game of chance: It can be favorable or not, but whatever shape it takes, its presence will always be occasional, brief, and impermanent. We have found that of the people who have won big sweepstakes prizes, many lose everything they gained, typically within four years to seven years of hitting the jackpot. Furthermore, their personal relationships with family, friends, and colleagues often have been seriously affected because of problems stemming from avarice, jealousy, and greed. On the other hand, since those who create their own good luck owe success only to themselves and their own initiatives, not just to a random roll of the dice, they are acutely aware of the origins of their good fortune. Moreover, having seen it work before, they know and understand the process that produces it, and know the same principles can be put to work again and again. The problem is that we often seem to forget old principles based on common sense, which basically say that we must work, be aware of our actions, and take responsibility for correcting them when the need arises. The person who grasps that wisdom is lucky indeed.
When I get back from my walk I am going to read your words and Ramcharger's to.8)
There's a difference between ignorance and stupidity.
Ignorance is not knowing any better.
Stupidity is knowing, but doing it anyway.
--Me--
"It's in the struggle itself that you define yourself."
-- Pat Buchanan
LOL!
Good one RC :cheers:
So other wise sow your seed and share the things you have learned with out looking for praise :cheers:
"If I had to select one quality, one personal characteristic that I regard as being most highly correlated with success, whatever the field, I would pick the trait of persistence."
-- Richard DeVos
"Love what you do, or don't do it. Don't make a choice of any kind, whether in career or in life, just because it pleases others or because it ranks high on someone else's scale of achievement or even because it seems to be, perhaps even for you at the time, simply the logical thing to do at that moment on your path. Make the choice to do something because it engages your heart as well as your mind. Make the choice because it engages all of you."
-- Carly Fiorina, chairman and CEO of Hewlett-Packard
"Enthusiasm is one of the most powerful engines of success. When you do something, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful, and you will accomplish your objective. Nothing great was ever achieved without enthusiasm."
-- Ralph Waldo Emerson
As long as it takes +++++++++++++++++++
What if you knew that you could reach your goal by taking just one more step? Would you take that step? At some point in the process of achievement, the final hurdle is reached. What a shame it would be to stop just short of that one last obstacle. Achievement does not require extraordinary ability. Achievement comes from ordinary abilities applied with extraordinary persistence. You already know you can do what it takes. To reach any goal, simply do what it takes for as long as it takes. It's really not that difficult to take just one step, to do just a single task, to make one bit of progress. And if you can do it once, you can do it again, and again, and again without much problem. Keep the faith and keep up the effort. Your persistence will get you there.
-- Ralph Marston
I like it.
If your gonna be dumb you better be tough..
;P
As you ramble through life what ever your goal, keep your eye on the doughnut and not on the hole.
Kitchen magnet on our fridge.
"It is a peculiarity of man that he can only live by looking to the future. And this is his salvation in the most difficult moments of his existence, although he sometimes has to force his mind to the task."
-- Viktor Frankl, holocaust survivor and author of “Man’s Search for Meaning”
The Journey is more important then the destiny
Not sure of the publisher I just remember hearing it 8)
“A persons mind may be likened to a garden, which may be intelligently cultivated or allowed to run wild; but whether cultivated or neglected, it must, and will, bring forth. If no useful seeds are put into it, then an abundance of useless weak-seeds will fall therein, and will continue to produce their kind.”
-- By James Allen
17 Principles of Personal Achievement by Napoleon Hill
Lesson 1: Definiteness of Purpose Definiteness of purpose is the starting point of all achievement. Without a purpose and a plan, people drift aimlessly through life.
Lesson 2: Mastermind Alliance The Mastermind principle consists of an alliance of two or more minds working in perfect harmony for the attainment of a common definite objective. Success does not come without the cooperation of others.
Lesson 3: Applied Faith Faith is a state of mind through which your aims, desires, plans and purposes may be translated into their physical or financial equivalent.
Lesson 4: Going the Extra Mile Going the extra mile is the action of rendering more and better service than that for which you are presently paid. When you go the extra mile, the Law of Compensation comes into play.
Lesson 5: Pleasing Personality Personality is the sum total of one’s mental, spiritual and physical traits and habits that distinguish one from all others. It is the factor that determines whether one is liked or disliked by others.
Lesson 6: Personal Initiative Personal initiative is the power that inspires the completion of that which one begins. It is the power that starts all action. No person is free until he learns to do his own thinking and gains the courage to act on his own.
Lesson 7: Positive Mental Attitude Positive mental attitude is the right mental attitude in all circumstances. Success attracts more success while failure attracts more failure.
Lesson 8: Enthusiasm Enthusiasm is faith in action. It is the intense emotion known as burning desire. It comes from within, although it radiates outwardly in the expression of one’s voice and countenance.
Lesson 9: Self-Discipline Self-discipline begins with the mastery of thought. If you do not control your thoughts, you cannot control your needs. Self-discipline calls for a balancing of the emotions of your heart with the reasoning faculty of your head.
Lesson 10: Accurate Thinking The power of thought is the most dangerous or the most beneficial power available to man, depending on how it is used.
Lesson 11: Controlled Attention Controlled attention leads to mastery in any type of human endeavor, because it enables one to focus the powers of his mind upon the attainment of a definite objective and to keep it so directed at will.
Lesson 12: Teamwork Teamwork is harmonious cooperation that is willing, voluntary and free. Whenever the spirit of teamwork is the dominating influence in business or industry, success is inevitable. Harmonious cooperation is a priceless asset that you can acquire in proportion to your giving.
Lesson 13: Adversity & Defeat Individual success usually is in exact proportion of the scope of the defeat the individual has experienced and mastered. Many so-called failures represent only a temporary defeat that may prove to be a blessing in disguise.
Lesson 14: Creative Vision Creative vision is developed by the free and fearless use of one’s imagination. It is not a miraculous quality with which one is gifted or is not gifted at birth.
Lesson 15: Health Sound health begins with a sound health consciousness, just as financial success begins with a prosperity consciousness.
Lesson 16: Budgeting Time & Money Time and money are precious resources, and few people striving for success ever believe they possess either one in excess.
Lesson 17: Habits Developing and establishing positive habits leads to peace of mind, health and financial security. You are where you are because of your established habits and thoughts and deeds.
" I started in Vaudeville at age seven and never had another job. I was blessed to be succesful in my work, something I loved. I would have done it even as a failure as it is better to be a failure at something you love than a success at something you hate."
George Burns at age 95
"So what do we do? (Anything - Something…) So long as we don't just sit there. If we screw it up, start over. Try something else. If we wait until we've satisfied all the uncertainties, it may be too late."
-- Lee Iacocca
