440outlawdart
after going through so many 727s starting to be a expert,have the tranny checked out for the rear sprag
Yep time to pull it out and inspect.I had my perches tear off and I spit out a u-joint at launch.I had to have all my internals swapped over to another 904 case.Also had to have my convertor hub replaced(bent)Here,s pics of my casing after the mishap.Don,t second guess the damage this will cause.Get your driveshaft rebalanced also.I have a 3500 stall but starts pushing me through the lights at about 1800-1900 rpm. When it snapped I hit the rev limiter at 6200 then immediately shut it down. Oh I just found my problem by the way. The yahoo who welded my perch plates on for my relocation didn't do a great job at all. My diff is spinning on the perch plates. I bet it twisted changing the pinion angle then boom. Well he's done doing my welding. I don't see any cracks in the tailshaft but im going to drop the cross member to make sure. These are times I wish I had a welder.
