No kill like overkill!
I bought mine off a guy on eBay, it was narrowed to a-body specs (52.4" & 43"), and used Yukon 28" axles, green bearings. I used 11 x 2.5" brakes off of 70 B-Body. Nothing like a Dana peaking out from under the back of the car!
So all those Ford Dana 60's are the same as Mopar Dana's? I found one from a 3/4 Ton Ford pick up. Will it work if I shorten it and just change axles? Which backing plates do they use? Thanks.
Can you buy the ends somewhere are do they need to come from another Mopar rear end. Which do you use 8 3/4? Thanks
