Im having an issue where my alternator will be regulated up until about 2000 rpm. when revved higher it will stop regulating
Always start help posts with
- Year
- Car
- Engine
- Trans
- Modifications
- Last work done
- And in this case what alternator (round back, square back 1 field wire or 2)
- What regulator you have (small with one screw on and one press on connection or larger with triangular connector)
How do you know it is no longer regulating?
Most alternators have more charging ABILITY at higher RPM.
I capitalized ABILITY because like the wires in your house, if you plug in a 25w lamp it works if you plug in a 100w lamp it works, the power company is not over charging your house. They are providing enough power for your needs as needed.
Your alternator and regulator will not over power anything. The voltage might go up higher due to a bad regulator or wiring.
What guage?
If the Ammeter is going from center to the right then you have a lot of electrical load being PULLED by devices or battery
and everything else is probably getting more power too
See above. Power is what a device PULLS not is supplied.
I have no clue what it can be because i've changed the regulator twice, regrounded the regulator, messed with the field wires and plugs
Because you said "wireS" I assume you have an electronic voltage regulator ( larger rectangular box with a triangular connector.)
That also suggests you have a (most likely) square back alternator with 2 field wires (Isolated field)
If your car did not origionally come with this alternator and regulator setup you may have gotten the wrong alternator from the parts store.
Again a lot of guessing because from your first post you could be working on a 65 mustang.
The alternator was bought maybe 8 months ago but wasn't driven all winter. I don't want to drop 50 bucks on an alternator if it's not the issue
Worst case is you pull the alternator (2 bolts and some wires) and bring it to your local parts store and have it tested.
Also most parts stores have testers they can put on your car when it is running.
After you give us the details of your setup we all can be more helpful.
