does it make any difference if you crank it in neutral instead of cranking in park?
The car wont crank/turn over if the shifter is in neutral. It will only crank/turn over if the car is in park.
really?
Agreed on the transmission. But I can't see how his brakes suddenly got all screwed up.Are you sure this isn't some sort of brake problem? I've seen cars that would roll in reverse fine but as soon as you try to go forward the brake binds up. If the trans was fine before, I seriously doubt that disconnecting the linkage for a manifold swap is going to prevent the car from moving forward? Besides, the vehicle should move forward even without the linkage hooked up shouldn't it? It will burn up the transmission if you drive it that way, but it should be fine to go up and down your street once.
trans and or TQ FUBARWe tried unhooking the linkage and the car didnt do anything different. I actually believe when we did unhook it it does the thing where you have to rev it a bunch before it starts moving (that's what it does when the linkage is to loose).
i'm guessing the transmission or torque converter are "fucked up beyond all repair".Idk what this means.
My son had fun helping today, he really just played on his computer. Then my daughter got upset she wasnt the one being able to help. So I had her press the brake pedal a couple times just so she could feel like she did something, she was happy then.
FUBAR
glad the kids are having fun helping though
If the carb is fully wide-open when the gas pedal is floored, at least you know the throttle cable is adjusted properly. So check that with the tranny cable disconnected. Adjust as necessary, and don't touch the throttle cable again. Now attach the tranny cable. At wide-open with the gas pedal floored, if the lever on the transmission is 99% all the way back (basically against the stop) you have the tranny cable adjusted approximately right too. But if the tranny cable is now stopping the carb from going wide open, then you have no choice but to put a little more slack in the tranny cable. Work in 1/16" adjustment increments until that tranny cable does what it's supposed to do. Even if it only pulls the lever back 90% of the way, you should be able to drive the car. Adjusted this way, the car should be drivable, and probably will be shifting good. If it isn't working you must have something else wrong. I am no tranny expert, but the next thing I'd check is to see if the fluid is getting pumped in and out of the cooler. It might be plugged. Stranger things have happened. One more thing to look at if you cannot get the tranny cable to work like it's supposed to is this: Ideally, the lever on the carb and the lever on the trans need to have the same "ratio". Measure from the centerline of the shaft(s) to the hole(s) where the cable hooks onto them. Both levers need to be the same length.
Hey Doc, I think you need to see a doctor. It appears you have an appendage growing out of your chest.
Nice shoes, by the way.
What's it look like in the bottom of the pan? Any sludge or metal paste?
Ouch. My 904 looked about like that when it decided to stop reversing.
If I were you, I'd just go ahead and put the pan back on and start pulling the trans. I tried to leave mine in-place while slowly taking more apart hoping I didn't need to rebuild it.. I should have known better. My uncle is a transmission mechanic and he would always say "as soon as an auto does something it shouldn't, it's time to pull it."
It's not as bad as it sounds so long as there's not major damage to hard parts. I think my kit cost a little over $200... But I don't remember if I replaced the bands or not.
