I don't believe so -- I think it's a clip for wire hold down
Yes the male spade on the limiter is for added ground wire although there was no wire in every build or application of that limiter. Many assemblies included more plastics so a chassis ground wire as used there to ground most everything on the board it was plugged into. Male spade on headlight switches is another example of same.
doh - looks too big in the pic to be an electrical connector.. sorry.
