hands down easiest way to renew its appearance is throw a dash cap over it. If you want to remove and replace the original you'll need to remove the instrument panel, glove box , etc.. to access the attaching hardware. 5 hex nuts across the top and 1 sheet metal screw in each of the turned down ends hold it on.
