mopops
temp&fuel gauge don"t work-changed dash-checked again-no work--any way to check the dash regulator? thanks mopops
Yes you can bench test it.temp&fuel gauge don"t work-changed dash-checked again-no work--any way to check the dash regulator? thanks mopops
working on 72 dart swinger-i have 2 dashes-2 regulators-same thing with each temp-fuel don""t work-i have a test meter and have some skills. just don"t know what to look for? thanks for any help you may offer-also need to know how to know what speedometer gear to use for 904 TF with 355 gears?^^As above, I take it you do not have a Rallye cluster? What is it that you are working on? Year / model?
"Other things" can enter into this.........the harness/ PC board connector, loose connector pins, and BAD CONNECTIONS at......
The pc board to limiter "socket" as well as the nuts on the gauge studs. It would not be unheard of to end up with both gauges bad, or wiring / sender problems in both gauges.
got temp to work-looks like the gauge nuts not making contact-re grounded cluster and body-am hoping fuel will wake up thanks for taking your time to help me,hope i can repay someday gjgloverthanks I will ck when it gets out of the 90's here g j glover
