De-Pin a headlight switch connector and selecting new pins
SlantedMark4
'74 Valiant 225 /6
Switzerland
I have never done this so it might be a very stupid question. I have absolutely no clue how to de-pin a headlight switch connector.
My situation:
Because the windshield gasket is leaking, water dripped into the dashboard and inside the electrics of the cluster. The headlight switch connector pins are completely rusted and it seems to have had a short earlier because the (new) headlight switch has melted plastic on it and the connector itself is completely gone.
On the plus side, i have an old connector on an unused dashboard harness which I could use, but how do I have to remove the wires/pins without damaging the housing?
Easiest way is to get a new connector but I have only found 9pin connectors instead of the 7pin connector.
May '74 built Valiant, Slant Six, 4 door
See how the terminal openings are rectangular but they have that little notched area on one side? Push whatever tool you're going to use into that notched area and there is a little tang about halfway down the metal connector that will press down. Then pull the wire out.
You may have to push the wire forward first, push the tang down and then pull the wire out.
This is the notch
This is the little tang
Good video.
take a snapped hacksaw blade
grind 1 inch length of the tooth side down until you end up with a strip that is the width of the hole in the connector. trim length if necessary to get the right amount of pry/press/twist to ping back the tang
press the none ground end with the blade mounting pin in it into a handle made of epoxy putty or cork or hey.. drill a split bit of dowel and bolt it on to the blade. you only need to make this tool once..... with a handle on it, it looks less like scrap and you won't stick it in the scrap bin
push the thin end down the key slot in the connector and push or pull out the spade or spade receiver.
raise the tangs on the new connectors
check then crimp. the spade type you have is the easiest to deal with, they are rear loading, crimp and load into plastic carrier
pull or push connector back into place, until the tang pings into place
Update: I just got home 20min ago and rushed straight to try your advise and yes it worked
Thank you all!
Now I have to check the car's pins. I think I have to replace them with new terminals but hopefully not.
I would find replacements and do so, End of story. Anytime these are overheated, loose from any cause, rusted, corroded, they need to be replaced. Not only can they cause melt damage to the plastic connector housing, which are hard to replace, but they can also damage the switch itself.
If you don't have the proper crimper "W" pattern, just crimp them the best you can and then solder them. Get on ebay, buy a small bottle / can of either paste or liquid rosin core (for electrical) flux, and get some lead based electrical solder. DO NOT let someone steer you into the plumbing section of a store!!! That is acid core solder and acid flux!!!
Also if you have not done so, read this:
Some have criticized that article, and the way they do that bypass, but the article DOES point out the problems with the bulkhead connector WHICH ARE the same terminals as your light switch. In particular the ammeter circuit can be a problem.
The old connector is completely gone but I think the terminals look okay, except for the red wire. I think I can reuse them...?
IMHO
Green arrow look fine
Red arrow bad
Red square really bad
Yellow arrow might be ok.
You can tighten up the good ones.
CAREFULLY squeeze (green arrows) a little bit.
NOTE:
all the metal on the terminals have a finite number of times that can be bent / moved.
The tangs for instance, open or close them maybe 2-3 times and they are likely to break off.
I wouldn't have an issue only replacing the red one. You may have to cut the wire back and splice a wire in there so they're all the same length again.
No need for a crimp tool. Just use a pair of needle nose to crimp as close to the factory crimp as you can and then put a dab of solder on the exposed copper like you see on the black wire there.
I have searched the internet and I found this:
Mopar Male Female 12 AWG Gauge Wire Wiring Harness Terminal Crimp Connectors NOS | eBay
These are the right ones? The gauge wires are same as the light switch wires thats no question.
I have also found this:
Female Spade Terminal Set (5x) : 14-12 Gauge
The second link looks closer to the type. The first link looks like the type you'd use in the bulkhead connector. The end of the female connector looks different if you compare it to your pictures.
so the terminals of the bulkhead are different to other connectors?
IMHO
Red arrow bad
NOTE:
Okay I start with the red wire and decide about replacing the others based on my skill
Proper crimping is a bit of a skill and you need the correct tools.
I would do some test crimps to get the hang of it.
I can not stress the proper tool for the job.
Typical parts store crimper does not do a proper job.
I believe so. Look at the two links from your post and pay attention to how the second link shows the female connector basically being flat on one end while the first link has a little lip there. I used the connectors from your first link when I rebuilt my bulkhead and everything worked out fine.
The connectors from your second link look like the connectors from your headlight switch pictures. They don't have the lip on the end. That lip could potentially cause the connector to not seat correctly so I wouldn't use the style from the first link on your headlight switch.
The 1st link, all the female connectors have a "lip" as mentioned. That style as far as I know was only used in dash harness for heater resistor? Maybe part of ac harness? Also for oil psi sender under hood.
The rest of females were same as the Aus listed ones. PRICEY! Chk for a thread by @Mattax about Chrysler terminal sources. Buy a bunch lol
