Dead stock bottom end quickness
Thanks for the info. I looked up their website and will be contacting them today.
you won't be disappointed...he spec'd my two last cams that I ran which were both on the money to what he said, and just finished my latest one for build #3. I am confident it will do what I want it to, it always has so far.
he will explain to you why he picks the cam he does and how it will make the power too, which is nice so you can get an idea of how your getting that stock bottom end to haul
This combo was run in the late 80's, so is a dinosaur set up. 69 440 short block with cast pistons, MP .509 lift cam. 906 heads with big valves, homeported with MP templates, shims cut out of pop cans and put under rocker shafts for more rpm. Motor rolled around on old tires to assemble because I didn't have an engine stand. 3.91 gear,29x10 slicks. Hooker fenderwells. 69 Barracuda. 11.66, was a real grin till a piston broke.
