Decode Help
63spf
DODGE'S ARE KOOL BUT PLYMOUTH'S RULE !
Kona , Hawaii
Please help decode, my build sheet seems wrong
CAR: Plymouth Barracuda 2 Door Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 4-Speed Manual Floor Shift
TIRES: E70x14 Red Side Wall, steel belted
BUILD DATE: December 30.
AXLE: 3.91 Rear Axle Ratio, Sure Grip
INTERIOR: High Trim Grade Black Interior.
PAINT: Monotone Bright Blue Metallic Paint.
OTHER: Black Upper Door Frame Color.
MOLDINGS:
25: Drip Rail Mouldings
78: Wheel Lip Mouldings
ABC OPTIONS:
A1: 26in Radiator
F7: Barracuda Formula S Package
R1: AM Radio
S6: Unknown Option
abc OPTIONS:
u1: Sold Car When Built (Somebody Ordered It)
Thank You,
Dec. 30 1968 , wouldn't that make it a 69 car ?
Ok build sheet says Dec. 30 1968. Thought was strange. Type O
I am doing a FULL resto. trying to find parts is crazy in Hawaii. Any and all help is gratefully excepted
  • 68 form S.pdf
Yes, it was an option as part of the HD cooling package.
How do I find a 26" Rad. ? car only had motor and Tranz.
No, Rearend, no springs, no interior, no Radiator . Missing so much but worth the resto I think .
You can find OEM style out there onthe internet or go with something like this (you need to call for the 26”)
Barracuda (66-69) 22" Small Block Radiator
Thank you but that's not OEM , I am trying to do a resto with all Original parts . If that is even possible , Its only way to get the REAL money for ol' Blue . One of 5 every built, or so I was told . Thinking car should be worth $50,000. or more . Well , if market gets better . Only @ 150 , 383/4speed Notchbacks were built in 68.
  • production Numbers.pdf
Then you are going to have to search the internet for an OEM 26” radiator.
FYI....
According to the Chrysler Production Code Book Tenth edition (Galen Tag Service):
1968 Barracuda Hardtop 383 Formula S 252 estimated built
Hardtop 383 Formula S 4 Speed 153 estimated built
Hardtop 383 Formula S Auto 99 estimated built
Went back and saw your production numbers, which I like better. Anyway you look at it there aren't very many still running.
Sorry but no, there was never a 26" radiator available for A-Body's until 1973 when the core supports changed. The SPD is December 30, 1967. Be nice to see pics of the broadcast sheet.
Figured it was a Galen decode, not always 100% right. His typo is the date, supposed to be 1967. Please post pictures of the core support because I have never seen a code in the "A" section of the fender tag, and the 26" radiator code is for the other body types. Also, I would love to see a picture of the heater delete vent on the passenger side of your car under the dash! S6 is for the heater delete.
Your 68 should have a 2898033 3 core 22” radiator.
Glenray stopped producing these so it will be hard to find and hopefully you can get a decent rebuildable unit.
Picts when I first started, was a rotted mess. But looking better every day !!!
