Decode Help
Almost looks like it was set up for A/C?!? I do spy the vent box though...
No AC, No unit, No Pump on Motor No hoses. Never had AC, Maybe just a standard look for a 68 ? I don't know , still learning every day on this Notch. My 63 Plymouth was an easier Build.
The 033 radiator is going to be an expensive purchase, I've seen them go for up to $800, and that's needing a rebuild! We sold one awhile back for $400, which was a steal for the purchaser!
Do you have the core support? Measure that opening.
Glen-ray may have the parts to put one together. Definately worth contacting to check on current situation.
You see, my dilemma . I am trying to do a proper Oem Resto. And am having a hard time with it.
Told you before you will be challenged over there in Paradise! The plate over the heater blower motor hole is not factory, correct yes? Do you know How or where the car got there from?
Was told was factory, car has been in Hawaii over 20 years. I don't really know all the info. I just want to restore it right
