Decode Me Please
ihave67cuda
Active Member
Tampa, FL
Hello,
I am relatively new to Mopars and this site. I just bought a 67 Barracuda about three half months ago and have progressively been restoring/mod her. She is currently being rewired.
But nonetheless, I have been having trouble trying to decode the panel plate. I have however been able to decipher the VIN.
The numbers for the panel plate:
'abc'
b=4
u=1
'ABC'
D=9
F=7
G=0
S=1
T=4
X=1
AX= 4
TRM=H6K
PNT= WW1
UBS= T
BH29 32 5285 615 02018
Any help on deciphering this will be much appreciated.
Thank You,
Z
1967 Plymouth Barracuda
Built June 15, 1967
273-4 bbl, 235 hp
904 automatic transmission
D70x14 redline tires
3.23 open rear end
Vinyl bucket seats
Copper trim color
White exterior paint
Medium copper upper door frame paint
Front disc brakes/rear drums
Air conditioning w/ heater
Vacuum gauge
All glass tinted
That G=0 code does not come up on any decoder I can find.
Does your car have an 8-track, air cleaner package, deluxe seat belts, or does the passenger seat recline? or some other odd option?
Are you missing mirrors, or power steering, or something?
Do you have the build sheet?
Send $45 to Chrysler and let me know when you get the build card.
http://www.chryslerheritage.com/newsroom.do?id=390&mid=135
Welcome to the FABO Family!
The build sheet or broadcast sheet is usually under the rear seat slipped up into the springs: be careful the paper can be very delicate, if it is, get a good digital photo before removing to be safe. Sometimes they are taped to the top of the glovebox insert up under the dash.
That copper interior is beautiful when restored. That is a nice find! Good luck with the build!:cheers:
Sorry for the delay in response. I'm in Tampa Fl.
The Barracuda has power steering,AM/FM radio, other than that nothing extraordinary. I do not have the build sheet...was missing
Some good news though. Today I found a green 70 Dart Swinger. Needs work on the roof and the pass. quarters are damaged pretty bad. Other than that its complete and solid
Is anyone able to decode this from the Dart?
H21 M25 M31 M43 R11 V5X
V1F U F11 G33 H51
GF7 H2F8 GF7 C04 222688
E24 D31 LH23 C1R 174989
Thank You,
Are you sure this isn't a '71 Dart Custom? Even though you have this decoded all ready, I have been running through the #s for the past 10 minutes and will post my decode. I haven't done one for many years so it was more of an exercise for me.
Update: I figured out this was a '71 Swinger model. I mixed up a couple of #s.
It was easier for me to paste/copy your code info so they may be a bit out of order but you will get the jist of it. Again, I haven't done a decode in awhile so it took me awhile to figure out the codes. Although you said this was a '70 Swinger, everything is pointing at it being a '71 Swinger.
H21: Heater w/RHD
M25: Drip Rail Mouldings
M31: Body Belt Mouldings
M43: Grille Trim Mouldings
R11: Radio-Am Music Master (2 Watt)
V5X: Mouldings-Protective Vinyl Insert Body Side (Black)
V1F: Vinyl Roof (Green)
U: Build to Specification for USA Order ('71 & Newer)
F11: 50 AMP Alternator
G33: LH O/S Mirror REM/CHR/RAC
H51: Air Conditoning w/FT Heater
GF7: (Body Paint Code) Dark Green Metallic
H2F3: (Trim Code): H=High Trim Grade, 2=Vinyl Bench Trim Code, F3=Trim Color-Green. Note: I am not sure if F3 is light or dark green. Are you sure your fender tag doesn't say F7 instead of F3?
GF7: Upper Door Frame Color: Dark Metallic Green
CO4: Scheduled Production Date: December 4, 1970
222688: Vehicle Order Number
E24: 225 6 CYL 1-1BBL (145HP)
D31: A904 3-Spd A/Trans
LH23C1R: L=Dart (Car Line), H=High (Price Class), 23=2 Door Hardtop (Body Type), C=225 1-1BBL (Engine), 1-1971 (Model Year), R=Windsor Ontario Canada (Assembly Plant)
174989: Serial Number
BTW: There were 60,939 6-cyl Dart Swingers built in '71.
