Deep sump Pan
Yall that are doin this to the pan....what are you doin for extendin the pickup?
Why the epoxy?
on the out side... epoxy primer... is hard as nails and will fit very nicely with the flat black color...
i should be getting to the pick up next week, cut a 1/2 i.d. tube to size and splice it into your stock pick up...
left the oil pan full of water to find leaks and found two pin holes... so moved the lead around and an letting it sit over nite... if no leaks i can blast it, mud it and paint it!
then time for pick up tube
so i made up the front and rear baffles... installed the rear 1.5" over the lip of the pan...
im not sure how far to go on the rear?? how much it to far??
thx ed
Moving right along !!!So when does the assembly line start ?? I'd be interested in one !!! I do have a new oil pump pick up,just haven't found a pan yuet !! If you're serious about doing them, I'm serious about buying one !!!:cheers::cheers:
once i finish it up we can talk about doing one!
Lookin good !!!! I've eyed up the pan stud kits on Ebay,and that's the route I want to go with too !!:cheers:
That's why we have Torsion bars .Just bump it up a little higher !!Gonna end up doing that with mine so I can get my fatt retired azz into the car easier !!!
haha yea probably have to... or just put the bumpers back in the LCA haha
