clifftt
What I meant to say was each cam will be ground a little different
and it should have a card specific to that cam.
That's not how I've found it to be unless a custom grind.
If you get her zero'd in it will pay in spades.
I'd also check the balancer and housing pointer for TDC, mark the hub and ring
on the balancer, dizzy height and run a bronze gear on the
diz shaft if you can.
I did check the balancer, it is "reconditioned" the machine shop furnished (my original was about to go). I found it off about seven degrees and remarked the balancer.
