Demon / Dart Sport quarter window glass
demon34071
Senior Member
Pittsburgh, PA
Double checking myself on this one….
Is the pop out quarter window glass the same on a 71/72 Demon and 73 Dart Sport.
I’m saying yes—- but the repop glass is showing two different part numbers at classic industries and AMD.
Can someone confirm for me. Thanks!
the snap hinge location moved in later years IIRC.
So does that mean the glass is not interchangeable between frames?
71/72 demon glass is not in stock
73 dart sport is though
It's the hole in the glass - the later 73 and up hinge is shorter, so the hole is closer to the edge. I suppose if you swap the hinge as well, it would interchange.
Thanks! Sounds like I’m waiting for demon glass to be back in stock for both sides. Or I need to sort through my 1/4 window stash and see if any gave really good tinted glass.
