So this is how far i got till i found that the float needles on my carb weren't closing, and during the testing of the fuel system, the main bowl filled to capacity and then leaked out the sight glass. This was not due to high pressure either..just bad craftsmanship by Barry Grant (this is my 3rd Demon carb and so far i'm anything but impressed. Go figure the company went under...cant imagine why..) So anyway..had the carb taken apart by a man who knows about these things, and it should be good-to-go. The gas vapor line i was trying to use for a fuel bypass line is not going to work (i believe its blocked up)..i guess thats what i get for trying to go the cheap route on ONE aspect of this build. So next on the agenda is to run a new line to the tank and trying it all over again..with any luck, i should have it started by the summer time.
