Rbob
Used for mock up only. Could not get pulleys lined up on cast iron water pump. My loss your gain.
Install a Denso 60 amp alternator onto any late model small block LA or Magnum Mopar engine. Works only with passenger side inlet water pumps. Uses the Denso 210-0106 alternator. The Denso alternator weighs 10 pounds which is about a 5 pound savings when compared to a factory Mopar alternator. The AR022 kit includes the brackets, bolts and spacers. Purchase the AR016 pigtail wiring harness if you need a Denso plug.
$35 and includes flat rate shipping to the continental US.
Shipping from 98584
Pay-pal accepted.
Thanks for looking:
Shipping from 98584
Pay-pal accepted.
Thanks for looking:
