Denso Alternator brackets Pre 1970 small block
Tim Murphy
Chicago
Can anyone provide me the part number for the correct 120 Amp denso alternator? Also, looking for the Albatross bracket kit that will mount the denso alternator for a Pre 1970 LA small block (1969 340)
AR engineering only sells the 1970 bracket kit.
thanks in advance!
thanks in advance!
I'm using the 60amp Denso, but FWIW, I used the OEM alternator brackets and added washers/spacers to get proper pulley alignment. It's a little tedious, but no big deal.
Mopar 1967-69 small block engine Alternator Mounting Kit 273 318 340
