I've been driving around my 73 dart for a while now, and usually I always have the windows open so I never hear any noises on the inside, I can only hear the exhaust (Pretty loud). Today I drove to work with the windows down because it was a bit cold out this morning, and going slow up to about 25mph there are no weird noises, but once I get going above that I hear kinda a humming/whining/slight ticking noise, that increases with speed. Its not my engine, its not that kinda noise, and besides when I stop to listen the noise is fine and the engine sounds perfectly quiet up front.
It seems like the noise is coming from my cluster, speedometer. The needle bounces around pretty good under acceleration and deceleration. Could this noise be a bad speedometer cable? Or a bad speedometer. I think its accurate besides the bouncing and noise.
If it makes a difference I have a 999 trans, and I also wasn't sure If this thread should go in this section or the interior section.
