Did i damage my 727
ARP makes great converter bolts....thin heads like they are suppose to be....plus blue locktite...
They are arp bolts and just ordered a cover that looks to have more clearance so we'll see
So.....what's the status?
Jeff
Currently at my dad's house just got off work so most likely tonight or tomorrow morning I'll take a look at it but I just need to fill her with tranny fluid and route the new shift cable. so far pan looked fine so went ahead and installed deep pan. When I hand shift it into park I try to move her and seems like parking pawl still intact. Is that a correct way to check beside removing tail shaft? Also found my noise problem from the inspection cover so ordered another one that looks like it will clear it converter bolts were good as well. Here is pictures of the damage.
Basically a triple wammy of problems and tackling then one at a time 2 down 1 to go hopefully. Had one other issue to of a rocker shaft bolt coming loose, glad I caught it though.
Okay guys well got everything back together cable transmission pan and shifter and minor things. Well I went to take it for a test drive today and it seems fine until it shift into 3rd and I hear and feel almost like a clunk and then it just vibrates alot and gets worse with speed, does this mean that possibly my 3rd gear is messed up or what could cause that? Driveshaft new rear end has been gone through and it seems to be coming from the transmission I feel, it so bad it shakes the steering wheel is messed up from this or idk where to go from here
Sounds like it has a slipping front clutch. How does reverse hold? What is the history of this trans?
Is your kickdown/throttle valve linkage hooked up and adjusted correctly?
Well, that isn't a good sign....only in third?
Jeff
Yeah seems like its only in third cause I'll hear a clunk when it shifts and almost seems like something moves. If I give it has in third it will just shake violently can't go past 30 it didn't do that before the cable incident
Reverse holds good I think got to give it a little more gas but probably the stall right? don't see a issue with it. I got the trans from a buddy that didn't know anything on it but when I pulled it open it looks clean and everything looked alright so I buttoned it back up. It has a shift kit in it I noticed as well and I have a 3k stall
Did something come out of adjustment? It didn't do this before the cable incident or maybe something happened in the transmission diffent while the cable fucked up? Idk I'm kind of at a stand still right now cause I checked all the suspension and everything I feel it's coming from the trans. And it does vibrate at all in park or neutral as well
Also as for kickdown linkage it has a lokar one and I think it's adjusted correctly I followed instructions but even out of adjustment would that cause a violent shake? Sorry for all questions
KD wouldn’t cause that. With a clunk like that it sounds like 3rd is coming on b4 2nd is finished releasing. Did a clip come out of a unjoint or is 1 buggered? Kim
The driveshaft u joints? The shaft and u joint are all brand new from Dr diff and they looked fine when I check them
How much did you drive with this trans before the cable incident? Was it a known good working trans?
There’s 3 things that you can look at externally as far as the trans goes. The shift cable, kick down linkage and fluid level. If those are all correct then the problem is inside. Front clutch could be slipping or 2nd gear band could stay applied. The 727 is one of the easiest transmissions to work on. But you may need a pro to check it out and fix it.
Shift cable was hooked up and fine, kickdown hooked up and adjusted, fluid level was good as well. I don't know if it was a good transmission but before the cable melting problem when I took it for that first small test drive it didn't do this. I'm not sure what this would be but I'm either going to have to rebuild it maybe get a TCI tranny maybe. When my next day off hits I'm going to look at it more. After dropping the pan and replacing with deep pan and all I put in about i wt to day 7-8 quarts because the deep pan and took forever to register. The engine it was attached to that i got from the guy had a blown head gasket and piston to head issues. That's the only history I have on it and when I opened it up it seemed clean other then the vb(has a shift kit b and m) has a lot of black stuff throughout it
Check out the tranny shops around u. Ask some mopar racers if u know any
Only one in my town is aamco lol I'll see what there is but tci is really that bad? Only got like 1100 budget for a tranny or so lol
Their also may be a member close to u to build u a tranny. If u weren’t so dam far away I’d build u one and ship it to u. Kim
What about a and a transmission that's near me they any good?
