Finally got to the point where we were ready to fire up the new 340. Primed engine according to instructions (spinning/cranking, etc.), hooked up the tach & oil pressure gauge. All fluids filled, gas good, poured about 1/4 gas into new carb and turned the key. BA-BA-BA-BA-SPIT-BA-BA-BA-SPUTTER, more gas...BA-BA-BA-VROOM! Everything going A-OK and then thermostat (determined later) didn't open. Ten minutes into the 20 minute break in and had to shut down IMMEDIATELY. Steam & Spew blowing out the side of the radiator cap. Hosed off, cooled down and removed the top hose, thermostat housing. Bad thermostat. Over $8k into new engine, new radiator, new hoses, fuel lines, carb, basically everything and a stinking $4 thermostat (also new) was bad.
Good news is there were NO leaks whatsoever of anything other than the spew from the radiator. I shut down immediately as soon as the steam started, but did I still screw something up?
What next?
What next?
