Difference between 67 to 75 valiant fenders
Strkr318
Wynnewood ok
Whats the difference between the valiant fenders from 69 to to 75. Hard to find good 69 fenders .
physically they should all bolt up. side markers are different and they moved the headlight buck around a little if i remember correctly
1967= No marker lamp.
1968= Round marker lamp.
1969= Rectangle reflector, no lamp.
1970=Revised rectangular reflector/lamp.
1971=Same as 1970.
1972= Surface mounted larger reflector/marker lamp, steel tab welded in to support steel tray that supports the grille.
1973-1976 Same as others but NO steel tabs, same side marker lamp design as 1972.
