joes68340s
I see that both intakes are rated the same rpm. But I am wondering what the big difference between them. If one was starting from scratch for a drag race only small block not stroker what would be the prefered intake.
the SV is sitting on a set of Shadydell Eddy heads...not bolted on...the SV is a standard LA bolt pattern..although i have read were they have been converted to fit a w2 head...
REALLY! Enough meat to make the port huh? Nice to know.
My IndyBrocks were CNC ported by Indy. Flowed 288 peak OOTB with poor mid lift numbers. I redid the valve job and replaced the valves. These mods picked up the mid lift numbers as much as 30 or so cfm, and peaked at 292. The bench used is a little stingy though.I figured the SV was for best use under a serious stroker. Just where this takes place over a regular Victor is a good question.
Now the SV is a standard bolt hole intake? Not a W series spacing right....
What heads are out there capable of making excellent use of this? The Indy head? Not Indy/Brock head.
Tony, what head are you making use of with the SV?
Skrews, what are your Indybrocks flowing?
