Differentiating Armrests
roughidle
Super Platinum Member
Pennsylvania
Does anyone have a picture out there that shows a '67-'68-'69 Barracuda armrest (front and back including bezel) next to each other so I can see what the differences are between them?
Thanks
D
Here is a pic of dads orig 67 cuda arm rest bezels
Here is a pic of 67 bezel AND pad I had a while back
Next pics are of fronts and they are the same 68-9. They "attach" to the bezel thru the holes on the sides.
In 67, there is a single screw that comes up from the bottom of the bezel, then 2 more screws to attach bezel to the door. Hope this helps.
:cheers:Thanks Steve! That's exactly what I needed. Wasn't sure what year it was that had the "ledge" in the bezel that the pad sat on. Thanks again!:cheers:
