fstfish66
does any one know,,where i can get a O - RING for a 904 trans dip stick tube ? thanks in advance,,,
Stop in at a local tranny shop. they usually have small stuff like that laying around.
X2 and by the way, 727 and 904 take the same o-ring for the filler tube. Part number 3291L in my after market parts catalog. All the same from 1962-1999. They also started using a boot type seal in 1997.
Will the "boot type" seal fit the older trans?
Do you guys use any rtv or anything, or just lube up the o-ring and slide it in? These things are notorious for leaking.
