Jim Lusk
This may very well be the last one I build as cores are getting just too expensive. This K-member has had all seams welded, LCA pin tubes welded from the inside, and extra support welded in for the steering gear mount. Correct big block motor mounts are also included.
$350/trades considered. I will also install in your car. Estimate can be provided after discussing amount of work is needed (front end rebuild, disc brake install, etc.)
Will post pics of the k-member that is for sale tomorrow.
