Disappointed magnum head flow numbers....
"...in order to GO, you must FLOW"...where did that come from? I think head flow is the foundation that which all power is built upon.
Ok, does this mean that mean that my set I will be making around 500 ho ?? Let’s be conservative 450 hp
Depends on the rest of the build.
The issue is, it doesn't matter how you build the bottom, if the heads won't flow, you're not going to make the power without an adder. If the heads flow but them bottom end isn't built to make power, well, you make more than stock but not full potential.
The engine needs to move fluids/gasses in and out. That's where the flow comes into play.
The flip side is how effective you are in;
1; Making the most power out of what you have.
2; How effective you are in utilizing that power to go fast.
Shape is more important than flow. All day long. A quiet port that doesn’t flow well in reverse is better than a noisy port that flows 85% in reverse.
I realize that I need good
exh flow that is why I put a nitrous grind in it.
I anticipate around 500 horse on the combo with 150 shot of nitrous I was hoping I could accomplish it on stock heads
I don’t have the money for aftermarket heads that would definitely do the job
I jus want an estimate nothing is chiseled in stone
360 mag
Stock block/ heads/ crank/rods/ 9:1 pistons
Edelbrock knock off airgap
MSD 6al my dizzy accel super coi904 w: 3500 converter
Massaged 750 dp
You already the specs on the cam engine is not that far off 380 crate
  • flow at low lift is important
  • matching the rest of the car to the engine is important
  • having the car "work" in itself is huge.
My point is, a well sorted out 385 hp powered Duster can beat a 485 hp powered Duster if the 385 mule is in a car that is well sorted out.
Bingo dead on.
Exactly what I was saying above.
Point one is not what my experience says. For more than one reason. I look at the numbers below about .200 lift, but unless something is way wrong I don’t care about that.
If you can test low lift at say...100 inches of water you’d see why the low lift numbers don’t mean much at 28 inches. Plus, the piston is in the way. Plus, you have to deal with cross flow at overlap. To fix that you have to reduce overlap and that’s a power killer.
Point one is not what my experience says. For more than one reason. I look at the numbers below about .200 lift, but unless something is way wrong o don’t care about that.
I should have said what I meant at low lift. .400
360 mag
Massaged 750 dp
With a 150 shot 500 hp should not be difficult to hit with magnum heads.
Listen, comparing flow numbers you found on the internet is like writing food reviews by reading the menu.
#1 no two flow benches are the same.
#2 no two operators are the same.
#3 no two weather conditions are the same, and this matters because flow machines do not suck, they cause atmospheric pressure to blow.
Notice I didn't even get into heads, valves, cam dynamics, etc. If you're reading flow numbers on the internet trying to decide what heads are best, you're not driving at a level that it will matter.
Horsepower on a nitrous boosted motor at the kind of power level you're talking about is primarily affected by nitrous jetting. The Magnum head has a decent exhaust side which will help accommodate the nitrous. Head flow becomes a little less critical factor when injecting torque from a bottle. I personally wouldn't spend a lot of time on a set of Magnum heads unless you just love them. if you're going to upgrade then step up. But that being said 500 horse range is definitely achievable with Magnum heads on the juice.
Thanks, I did a lot of research to set this up. I figured that what I have now is close to the level of hp I could make without spending a lot more and keep from blowing the motor. I will be able to have lots of fun with 500 hp on the
street, when I get traction set up. Off the juice it will be a 13 sec mild plus engine which my wife can still drive to the grocery store which is exactly what I want. and hopefully in the high 11’s on the juice, which I consider to be a respectable in a daily driver. It will be like what Hirohito said when the japs destroyed Pearl Harbor “I keel as if we have awakend a sleeping giant.”
Just for comparison my 470 stroker Dynoe’d at 655 hp. Heads flow 320 cfm. I believe the formula is 2.06 hp per cfm. Mine is actually pretty dam close. Volumetric efficiency was 108%. I will add that some motors put out beyond expectations while others fall short. I can’t stress cylinder prep enough. Having straight round bores is an absolute must. Kim
360 mag
Massaged 750 dp
I can give you some track numbers if it helps on my '71 Cuda with stock 340 motor, 2.02 non ported heads that are around 215cfm@best+HS dom intake, 850DP, .590"DC sft cam, 4200stall etc. etc. Motor only made 367fwhp, best mph was 108 NA, according to weight/mph. Added a 250shot but only got actual 158hp from it (525) for other reasons like too rich petrol jet specs back then (110n/110p) and not enough backed off timing but ran 122mph. So you can do it on stock heads, you should be able to get almost 150hp from a 150 shot if you tune it well with todays jettings etc., and your motor is up there with NA hp.
Very true. Rough, but a accurate estimate of what can be done without going nuts. I see the 2hp per cfm math as what a really good street machine or bracket racer can produce themselves without going crazy on an engine.
It is not the ceiling.
Now the CID X 2 for HP is another story, but yet again, not the ceiling. Also, of course, what the head is capable of on the engine and its size is a constant variable to what can be done easy or with pushing it.
A 360 cubic inch engine at;
CID X’s 2 = 720 hp.
Cylinder head flow at;
220 x 2 = 440 hp
280 x 2 = 560 hp
300 x 2 = 600 hp
Etc....
While the cylinder head numbers suggest a possible certain amount of power possible, it would be easier to make the possible power on a larger engine rather than a smaller engine.
OK 220 x 2 is 440 hp normally aspirated
How much more. Hp can i expect with a
150
Shot of gas
OK my build is based on the 360/380 crate, which i have read that regularly dyno at 400 hp, im hoping 530 hp and 500 torque, does that sound reasonable ?
I doubt it.
My 388" 360 based race motor started life with ported w-2 heads flowing 294 cfm intake, 13-1 compression on alky, 750 Holley DP, dizzy locked at 36 degrees, Crower solid lifter cam 580/580 with a 260 degrees duration @ .050... 575 HP @ 6,000 rpm.
Now I'm shooting for 625 with my 850 carb, more cubes, lighter valves and a better cam. Still might not make it...
I doubt it.
I think he is including a 150 shot in those numbers.
