Disc brake hose question
69hemibeep
AZ
I converted my 68 Valiant front drum to 73 disc setup and put the calipers to the rear do to an after market sway bar. Just looking before I order the rubber hoses I think they will be to short. What hoses have you guys used on your conversions???
..i think i bought a 90 degree fitting for the calliper and then a 10" standard brake line with a frame adapter...that was a few years ago.
I'm using the Aspen / Volare hoses. Work good
attachment.php
Hey Bob, Im about to do the same swap on a friends car. Apparently F body Volare/Aspen hoses work when you mount the calipers in the rear.
Yep I ordered everything a little earlier after some input on here. How is it going Adam?
Will those same Volare/Aspen hoses work on a 70 Duster with the 4 piston calipers?
