Disc brake question
DirtyDale
Im putting dics on my 65 dart. The brakes came off a 76 duster. Im also looking to rebuild the complete front end on my dart. My question is, can i order a complete front end kit for a 76 duster and be done with it or do i peace it togther from the two cars?
Thanks for any info...
Order it new. Why do it twice if your only have to do it once.
You are correct. The new parts should be for a '76 Duster. The idler arm and Pitman arm will need to be for a '65 Dart and you will probably have some parts left over (sway bar bushings and links) but everything else is usable. Good luck with the wrenching.
well....thats what i said.... If i can buy a 76 kit and use the rest of the parts on my 65.... Kit meaning NEW.
ok..thats man..
