disc brakes 4" pattern
upper control arms from a disc equiped car...
Wrong, upper control arm swap is only needed for the 73-up disk conversion.
The original kelsey hayes 4 piston spindle used the same small upper ball joint as the drum brake cars.
I've done 2 swaps from drum to the early 4piston disk setup.
