Disc conversion (ford)
SlantedDart
Michigan
Latest project is using some old rotors and calipers off my old mustang to convert to disc on my Dart. Custom brackets and spacers. Seems to look good, hope it functions properly! Fits a 15 wheel with room
Should be OK. The Doctor Diff kit is just the cobra version with the vented rotors instead of the solid ones from the regular mustangs.
I would personally switch to red loctite since it looks like the bolts aren't all the way through the nylocks. Those ones for the spacers with the thin nuts are a little low on thread engagement already.
assembly wasn’t tight yet
Can't believe that you used the "F" word in the title!!! I think you broke an FABO rule???:poke::rofl::rofl::rofl:
