disc conversion ?
1970-dart
Vermont
will the disc brake setup off a 74 swinger fit on a 70 ??
thanks in advance
Yes, but you need everything from the upper control arms out. And it will change your bolt pattern to 5x4.5".
ok perfect thank you so much. I have a 70 with a slant 6 and I bought a factory v-8 74. I am planned on changing everything from the radiator to the rear end if it would work.
