plumkrazee70
I have rewired the car using an EZ wire wiring kit and want to add a the brake light indicator from the block safety switch.
Just trying to understand how the bulb gets power. My thinking is: Bulb gets 12v one side and the ground goes to the switch on the block and the block also goes to ground? That way if the switch trips it completes the circuit via ground?
Is that right?
Thanks
Is that right?
Thanks
