NiceFishEh
Just purchased a custom set of 8.5 MSD plug wires with the straight boots for the 340.
No.7 wire is stretched across the engine and has very little slack in it, because it connects to the cap on the far side, ( passenger side).
My No.1 wire is at the back of the cap against the fire wall. All the wires would fit better if the No.1 wire was located at the front of the cap, then do the sequence.
If I rotate the dist and the No.1 cap wire to the front, (both 180 degrees), nothing changes, right?
Thanks
Thanks
