Distributor Shop in Bay Area?
Stroked68Dart
402 Crate Motor in a 68
San Francisco Bay Area
I searched through the archived post and couldn't find what I'm looking for so...
I live in the San Francisco Bay Area and have a distributor that needs put on a distributor bench and checked out and adjusted for my setup so I can use the vacuum advance and achieve max power with my motor combo. Does anyone know a good shop in my area to recommend.
As always, your ideas and advice are greatly appreciated.
Buy yourself a dial back timing light and use your motor to spin and adjust it. Do you have access to a welder?
Nope. I am kinda half good with the car and motor. I can do most everything but the distributor or welding is out of my are of expertise and something I would be hesitant to try on my own :-(
Check with member redfastback
He may be a viable solution.
Do you know what the car wants for ignition timing now, or does it need to be sorted out?
