txstang84
nope...I don't think it was a trim level. It was a 2 door hard top Valiant under the Plymouth name. Has anyone ever seen a 4 door Scamp?
Yes...with the Valiant front clip and rear sheet metal...Are the 73-76 Valiant Brougham still based on Dart body ?
Ok, I'll go along with that. So that makes the Scamp a model too, right?Also the Swinger is a model, not a trim package.
A model is designated by the first four of the vin number.
A trim package is designated by a option code.
For 1970
LL23 Dart Swinger
LM23 Dart Swinger 340
LH23 Dart Custom.
There is an A14 Dart Swinger Sales Package that be optioned on an LM car that added a vinyl top and more trim to the Swinger model.
I think the base was the Valiant. .......but I don't know for sure.Did they make a base model 2 door Scamp? What would be the upgrades?
What I meant was the 67-69 body style was no longer available as a 2 door, Duster than Scamp took over 2 door duties nether uses the valiant tail end like the 4 doors still does until they use dart bodies for both.A yes and no answer. Like saying a Coronet Super Bee. Not all Coronets were Super Bee's. Till 1971
Yup.Ok, I'll go along with that. So that makes the Scamp a model too, right?
Ok cool. So there it is. Scamp! I had not knowed dat. LOLThe OP shows "VH23" so it's a Scamp
VH23 is the key. What do we have 3 Valiant models in 72? The 1970 Hamtramck Registry - 1972 Plymouth Ordering Information - Valiant / Scamp / Duster Coding Guides
Code Description E24 225 1 Barrel 6 Cyllinder D34 TorqueFlite Automatic Transmission VH23 V = Plymouth Valiant / Duster
H = High
23 = 2 Door HardtopC2R C = 225 110HP(net) 1-1BBL 6 CYL
2 = 1972
R = Windsor, ONT, CAN344264 Sequence Number '344264' GF3 Paint Code: Medium Green Metallic E2F6 Trim Grade/Style/Color
E = Economy
2 = Vinyl Bench
F6 = GreenGF7 Upper Door Frame: Dark Green Metallic 617 Date Built: 6 / 17 / 1972 112478 Order Number: 112478 V1F Roof Type OR Color: Full Vinyl Top - Green U Built to Specifications for USA Order 22 Radiator Diameter 22" WIDTH C12 Shoulder Belts F11 50 Amp H51 Single Air /w Heater M21 Roof Drip Rail Moldings M26 Wheel Lip Molding R11 Music Master Radio AM V5X Black - Mouldings - Protective Insert Body Side END End of Codes
I believe that is for 1971 only? 1972 just had Scamp I think.
1972?No the picture I posted was from my car I bought from the original. I had never been painted before I bought it.
VH23
I think you meant 72?VH23 is the key. What do we have 3 Valiant models in 82?
A yes and no answer. Like saying a Coronet Super Bee. Not all Coronets were Super Bee's. Till 1971 when they became a Charger Super Bee. It's all in the wording.
