72ScampTramp
Scamp Tramp
I have a 1995 Dodge intrepid with a check engine light. I went to the parts store to have it checked and there OBDI connector was different then the one in the car. The one in the car i found is inside between the steering column and center console. Blue 2 rows 3 male blades. The guy the counter said there usually under the hood. Is there another one im over looking?
Symptoms: Car starts but dies right away. If i start it and hit the throttle and hold it at say 2k rpm for just a bit it seems to come out of it. Also chugs on the highway intermitten. CEL just came on the other day.
Thanks in advance.. MODS move this if not in right section thank you.
