Does my /6 sound right?
Good score, but…I surely hope your Dart has a manual transmission, because it doesn't look as if you got the kickdown linkage. It's totally different for the 2bbl setup. The 1bbl setup won't work.
Thanks!
I did infact get the kickdown linkage :).
I had to get the guy at the yard pick it up with a forklift so I can pull it off.
T'rific! If you didn't get the shorter 2bbl throttle cable (or the car you removed the setup from had the later square plastic ferrule rather than the round metal one where the throttle cable goes through the firewall) the correct cable is still available. ATP Y-156, for example.
