Does this 360 seem like a good deal?
64physhy
Weatherford, TX
I found this for sale for $2500. Supposedly has 6000 miles since it was rebuilt. The rings were also gapped for NOS, but hasn't had NOS run in it. Does it sound like a good deal? Seems like it to me. Does 420 HP sound like an accurate claim? Thanks, Dave
P.S. Thanks to those who talked me out of trying to build my 273, if there are deals like this on 360's.
Sounds like alot of gray area...
$2,500 is not change. I would get alot more information along with who did the work on the motor. 420 HP? With what shot or is that all motor?
Has it been on the dyno?
Casey Davis
Unless you are close enough to hear it run, or know the guy, I wouldnt consider any used engine what it is billed. Not a cut on used stuff, but it's hard to convince someone to take it all apart because you don't believe them. My $.02
forgot to put all the info in. here it is. quoted from tha ad
"420+hp 360 . 6000 miles on motor broken in correctly
synthetic oil used exclusively
performance parts list
060 over with Kieth black flat top pistons UEM-KB107060-8 $197.39
10.9 runs 91 only
Mopar Performance High Performance Oil Pump $59.95
cam gear with hardend tip $50
aluminum edelbrock performer rpm heads EDL-60779 $716.50 x2
edlbrock carb 750cfm EDL-1407 $269.95
lunati voodoo 268 513 cam LUN-60403LK $179.95
Edelbrock Performer-Link True Roller Timing Chain Sets EDL-7803 $59.95
msd pro-billet e curve distributor MSD-8504 $375.95
blaster2coil MSD-8202 $35.95
roller rockers from racer brown. 1.5+1.6 the very best for mopars $499
Racer Brown Billet Hold Down Kit $99.00
Holley high flow 80 gph 7.5 psi fuel pump HLY-12-838 $67.95
Edelbrock Single-Feed Fuel Line and Filter Kit EDL-8134 $51.95
-6 braided line with reusable fittings to carb $100
Malory plug wires MAA-775 $37.95
Powermaster XS Torque Starters PWM-9513 $224.95
new brackets and pullys dpe $200
rings gapped for 200 shot of nos motor never had nos run through it though never got around to getting a kit
$500 in machine work +$200 for gaskets rings berings
professional products highrise air gap I payed $200 at local speed shop
probably missing some stuff but these add up to 4752.99
I retarded the cam 2 degrees off lunaties center line so she would run on pump piss I meen gas. plus my ignition timing set to just barely run on pump no pinging or knocking. I painted it all blue when I put it in the truck for the stock sleeper look.I never did have it dynod but edlbrock did a build up of a 340 with less cam compression and cid. to the tune of 420hp this thing's a beast in my truck and was a rocket in my 3100 lb car I had it in"
Better hope it sonic checked good boring it .060 over or you'll have a 360 you can't keep cool. Also it should have been balanced using KB pistons cause their allot lighter than stock. Make him show you receipts!!!
