Jayman62
I will be swapping my stock 66 Dart's 1 barrel manifold to a two barrel super six manifold and Carter BBD. I read a different pedal is required since the BBD uses a cable for the throttle. The person I bought the manifold off of had this pedal from the same car, 73 or 74 duster. Does this look like it will work with my 66? I don't mind having to drill some mounting holes.
Thanks
Thanks
