I think camshaft profile was different too.I did state probably most of the power difference was exhaust system related. But you are correct in that the Caprice had slightly lower compression.
You didn't say 20% in your comments and I'm not interested in the video. Depending on what it is 20% is probably 2 or 3 percent low so now I'll ask how did they come up with 20%.
And remember I do not want to watch the whole video, which is why I asked in the first place.
and tack on another 25 with a 750DP!114? I hear he could gain 50-60hp just going down to like 108.....
Or it could just be a driver car and he is happy with what he hasand tack on another 25 with a 750DP!
but whatever. dude needs to ditch the zero and get with the hero-- should be running a 5.9 and that'd be like 100~150 more ponies. no one denies this.
Don't forget about flipping the offset on those pistons.
I do believe I detect sarcasm.....114? I hear he could gain 50-60hp just going down to like 108.....
The difference for the caprice was compression ratio too. I can’t believe this isn’t a bigger part of this discussion. All of this discussion also seems like all out racing applications. It’s not. Sure, run the tight separation but dialing back your timing to run on pump gas is a power killer or don’t and kill power with detonation.
Here you go "Rat" >
It's all in the "comments and responses" from the above Sorta Stock 318 Dyno Pull video above.
I copy the video link then I go pull it up on the YouTube website, where I can read the comments. Interesting, there is good info to be had there.
I guess we are right back to trying more than one cam to see what the engine wants.I'd rather have the compression and roll some timing out IF I have to than to lower the compression so I can run a bunch of timing.
How much timing would you be willing to lose ?I'd rather have the compression and roll some timing out IF I have to than to lower the compression so I can run a bunch of timing.
I said what I said, and if you did not read it or fully comprehend that, it is your problem.Iron heads too comparatively speaking but getting caught up wrong in the discussion at hand.
Why wouldn't you think you might have to try a couple of cams, gears, carbs etc.. To dial the powerband to suit you.I guess we are right back to trying more than one cam to see what the engine wants.
By what reasoning? I do agree that more area under the curve could be picked up, but 50 - 60HP is a bit much I think. About half that would likely be closer.114? I hear he could gain 50-60hp just going down to like 108.....
Eg.. total 32/30/28
So we've been in agreement this whole timeBy what reasoning? I do agree that more area under the curve could be picked up, but 50 - 60HP is a bit much I think. About half that would likely be closer.
I guess what I meant was there a limit how low you'd run total timing to gain more CR,Depends on RPM. Most engines (Can't say EVERY engine because I haven't seen every engine from every era but...let's leave it there) want less timing at peak torque and more timing at peak power.
Where that peak power is will determine how much total you end up with. An engine with peak RPM at 6k won't have as much total as an engine peaking at 7500.
To that end, I'm not sure why being able to reduce timing is a bad thing. You want peak cylinder pressure by 14-18 degrees ATDC. If you have to fire the plug at 40 degrees BTDC you have pretty close to 35ish degrees of crank rotation where chamber pressure is working against making power.
If you can fire the plug on that same engine at say 30 BTDC you have now reduced that negative work by 10 degrees. Of course, that's as long as you still get peak cylinder done by 14-18 degrees ATDC.
Volumetric efficiency affects timing requirements. Not many people would argue that. So think about what a locked out or an all in curve by 2500 power does to power?
Not only are you increasing negative working pressure, all that timing is beating up parts.
I was just saying that we are getting away from the original discussions.I said what I said, and if you did not read it or fully comprehend that, it is your problem.
No disagreement Turk. The situation is a matter of combustion efficiency beginning at the moment the spark takes place. A fraction of a second after ther spark occurs there is virtually no advance of the flame kernal as it establishes itself. Then slowly it begins to expand into the close molecules of air (O2) and fuel. There are still few molecules combusting yet, so heating of the cylinder charge is almost nonexistant. It takes 5° to 10° for the flame to expand to include much of the combustion chamber, so some heating but not yet a lot. At TDC most of the combustion chamber has flame in it, but combustion is not yet complete. That should be about 10° ATDC enabling maximum heating by around 15° ATDC. So yes there is some negative power producing pressure on the piston between the time of the spark and TDC. This is illustrated in DV's How to Build Horsepower book.Depends on RPM. Most engines (Can't say EVERY engine because I haven't seen every engine from every era but...let's leave it there) want less timing at peak torque and more timing at peak power.
That's ok I'm not a sticklier on my threads, I got all could get out of this thread which wasn't much It's free to take on a life of it's own now.I was just saying that we are getting away from the original discussions.
Yes, I have noticed these discussions do tend to do that. Baffles turds out of me at times.I was just saying that we are getting away from the original discussions.
