Does this sound right
The heads have just as much to do with peak rpm potential as camshaft, I'd even say more so.
Is that Canadian HP or US? I wonder what the conversion rate is.
Some run out of breath before it runs out of cam.
and some run out of cam before it runs out of breath.
IME it is the cross section AND the shape that dictate 90% of where peak power occurs. The other 10% are camshaft AND exhaust in conjunction with each other. I've seen an NA 1st Gen Hemi with a cam and only 220 @ .050" peak at 6700 RPM. J.Rob
Takes less cam to make horsepower and turn rpms with properly sized ports and intake for the respective cubic inches.
Thru the years, I’ve tested a few combos that surprised me in terms of where the peaks occurred.
Some higher than expected……..some lower.
