Dome Lighting Question
Electrical and Ignition
  1. '72 Duster Maddness
    '72 Duster Maddness Member
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    7:55 PM
    I've Just Done Some Wiring Upgrade Work To My'72 Duster Removed All Hacked Up Wiring, Replaced A Few Things When My Alternator Took A $¿/€€<°§ Car Is Now Running Fine And Ready For Daily Driving But Have A Problem With The Dome Light Have Followed The Wiring Diagrams And Still Can't Get It To Work
  2. Steven190
    Steven190 FABO Gold Member FABO Gold Member
    1,205
    619
    Jan 13, 2012
    Omaha
    Local Time:
    9:55 PM
    What is it doing? the dome light is a open ground circuit. Like the door close, the switch is open, open the door the switch closes and the light comes on.
  3. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    7:55 PM
    20171125_171158.jpg 20171125_171158.jpg 20171125_171158.jpg 20171125_171146.jpg
  4. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    7:55 PM
    As My Pics Show There Was A Lot Of Hacks And I Returned The Wiring Back To Almost Factory But I Lost A Few Pics Of The Before For Reference Need Help To Attach The Correct Wire To The Relay (Note I'm Not Reattaching The Map Light)
  5. Steven190
    1,205
    619
    Jan 13, 2012
    Omaha
    Local Time:
    9:55 PM
    Have you a manual? It will have a wiring diagram in it which will show the wire and color. I know that is is a loaded question, you may have the manual.
  6. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    11,143
    7037
    Feb 7, 2013
    Phila. Pa
    Local Time:
    10:55 PM
    Does it work from the headlight switch? That's the otherr way to turn it on.
  7. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    29,568
    9895
    Aug 28, 2009
    Wasting time here
    Local Time:
    9:55 PM
    Mymopar.com for free manuals.
  8. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    44,974
    12556
    Oct 14, 2010
    Idaho
    Local Time:
    7:55 PM
    1....Dome light should have power to one terminal of the lamp all the time. The socket is a 2 terminal socket THE SHELL does nothing.
    2...Second lamp terminal goes to yellow, and this is "common" with all other come/ courtesy lighting. You ground a yellow, the lamp should light
    • Like Like x 1
    • Thanks! Thanks! x 1
    • '72 Duster Maddness
      19
      3
      Sep 4, 2017
      La Puente Ca.
      Local Time:
      7:55 PM
      Thank You Everyone To Answer A Question Yes I Do That's How The Car Came Back To Life Thanks For Steering Me To My Mopar. Com When I First Started This Little Project I Will Follow Thru With Everyone's Suggestions And Keep Everyone Posted Thanks Again I Couldn't Have Gotten This Far In This Project Without Everyone's I'm out And When I Finally Give This To A Very Young Family Member (Navy) I'll Let Them Know Where To Find An Answer For Any Problems No Matter How Small Thanks Again And Now I'll Be Looking For My Second Project Ride Anyone Have A Early Dodge Truck I Have A Couple Of Power Plants Just Itching To Get Out There Crates Lol
      19
      3
      Sep 4, 2017
      La Puente Ca.
      Local Time:
      7:55 PM
