[WANTED] Door Glass Channel Seals/Weatherstrip, with slides
charliec
richmond texas
'68 Dart 2DHT.
Mopar Part No. 2932 230 (channel); Mopar Part No. 2841 646 (plastic slides). This is the plastic/felt strip that attaches to the front edge of the door glass and runs in the Division Channel.
I need a pair of them.
Good luck, I was told in early January by various vendors that those won’t be available till late spring or summer. Apparently the manufacturer is retooling to make a better product.
The fellas over at Dante’s was able to locate a set of the white plastic glides for me, so a big shout out to Dante’s. No luck on the channel guides though.
If you can locate a set of channel guides for a 67/68 B-body, I was told that they will fit an A-body. You may find them on Ebay, but for a price.
Good luck, I hope this helps.
Pretty much the reply I expected to hear, but I gotta keep trying anyway. Thanks.
'68 Dart 2DHT.
Call Jim Fillmore at Detroit Muscle Technologies. He carries them, and can probably let you know what's going on with them.
