Door panel removal
Petrilloa
Wyoming
I'd like to remove my door panel on the driver door of my62 valiant. I'm aware of the clip but can't seem to remove it. Any suggestions would be appreciated.
The door and window winder handles aren't held on by a clip, as in a lot of other cars. Instead there is a solid, knurled pin that holds each handle in place. You have to depress the door trim around the handle in order to find the pin behind the base of the handle. Use a small hammer and a punch or drift to drive the pin out, and then the handle will pull off easily. You may have to shove a small mirror behind the handle in order to see the pin. If the pin doesn't want to push out in one direction, try the other direction.
