cody.bourgeois
has anyone put 73 non vent doors complete on 70ish body? will it work. i assuming the answer is yes. input welcome. im wanting to convert to one piece glass.
curious why you want to go non vent. i've had mostly vent window cars, and now that i don't, i hate it
I think you have to change the drip rail chrome where the gasket goes to a 73up style cause I want to eventually put vent doors on my dart but was told those have to be changed to do it. So assuming the same must be changed to go to 73 up style
Not the external drip rail trim the 1.5 inch wide one that is one piece and in the channel the window sits in when rolled up. Also where upper gaskets mountnot worried about the drip rail chrome as of now its not going back on.
I would but My car is already painted and dont have extra or even know the code
I would buy all from ya if you were closer
I like the wing windows, get some air in the car with out blowing you out......
Bingo. Doug nailed it right there. Wing windows are great especially if your AC goes out or you don't have AC.
Also if there is a smoker in the car the wing window can be cracked to draw the smoke out.
no ac and smoker is obvious. ill have AC and a non smoker here. just looks cleaner to me
